OffsetSrf Tapered / ExtrudeCrv/Srf direction: surface normals
OffsetSrf defaults its direction as the normals of the surface being offset, but has no option to taper.
ExtrudeCrv/Srf Tapered obviously has the option to taper, but the direction parameter does not allow surface normals as input. This would be useful when a curve has been pulled/projected to a surface and needs to be extruded in relation to that surface.
I appreciate any suggestions.
So, what you are asking for, if I understand, is Extrude normal to surface (Fin command) with some taper angle form the normal, is that correct? Or is just the Fin commmand what you need?
Thanks for the reply. I had forgotten about Fin! Yes that’s what I mean, just with a tapered option. I feel that adding a draft/taper to any OffsetSrf/Extrude/Fin should be common, instead of requiring an entirely new command.
It also would be nice if Fin allowed you to select multiple surfaces (within a polysurface), but I know that’s wishful.
Hello, i already ask this some years ago , the Fin comand but with a option to give an angle. I dont know
if is a underused tool, but for me will be a great tool.
By the way, heinzler in what type of work do you need that tool.
-Pedro Neves
Oh I apologize if this is a repeat topic. But I agree, a draft/taper option would be helpful. I’m doing architectural/environmental design structures and furniture. For this particular project, I’ve pulled curves to a surface and want to extrude them normal to that surface with a draft angle.
Repeats are A-OK, we like to know when it comes up again…
I might be limited in my english comprehension, but what do you mean when you say you want to extrude them normal and with a draft angle? (it is this draft angle i am having problems understanding)
-Eivind
No worries, draft is another word for taper. A narrowing (or widening in reverse) of an extrusion.
Thanks, that did clarify it quite well.
But this should be able to do with scripting, what are your wishes? select multiple surfaces within a polysurface and then extrude and taper?
i can do my best to help you if needed, and if i am not able i will just ask in the scripting sub forum, those guys know everything and then some :wink:
-Eivind
The Extrude Taper command only works well for planar lines and arcs.
Every other input produces lousy results. In particular inputs that are not planar produce exceptionally lousy results. So I wouldn’t hold out much hope for a command that does what you want and produces good results in one step.
The best way to create an tapered extrusion normal to the surface would be to use the Flow Along Surface command. First flow your curve from the 3d surface to a planar surface of similar size. Then extrude the planar curve. Then rebuild or loft or refit the lousy tapered extrusion to get a good quality surface (or polysurface). Then flow the result back to the original.
Post a small example of what you are trying to do if you need more help.
FinAngle.rvb (3.2 KB)
Hello, some years ago i asked Pascal if he can help me with the FinAngle question and he made me a RhinoScript command, the script works in a single surface (no problem for me) , with a single curve (no problem for me) , but only works with curve without Kinks (very big problem to me) .
If someone wants to try the command, its uploaded , by the way i work in the Footwear industry (shoe sole).
-Pedro Neves
Completely forgot about that…
This feedback has been great. Thank you to everyone. Pascal’s FinAngle script works really well! Incompatibility with kinks is unfortunate but fine with me for now.
I may be taking the thread a different direction but I’ll elaborate more on what I’m trying to do. I’m taking form inspiration from this type of bicycle helmet and attempting to create exhibition structures from them (for a music festival). I created a shape with T-Splines, converted to NURBS, and pulled curves to the surface. From there I’ve been stuck on how to achieve these interesting extrusions normal to the surface. I want to keep the hard edges depicted in this sketch, (which is not mine btw) and ultimately make the structure asymmetrical. This FinAngle command gets me closer to the forms if I OffsetSrf and Trim, but I’m pretty sure this isn’t the ideal workflow. I’d really appreciate any thoughts or experience in modeling this kind of thing.
Answering my own question. This is a subtractive modeling process, involving a very articulated arrangement of booleans/cutters in order to maintain surface continuity. Rhino’s boolean commands can technically achieve this, but right now they are not optimized for it. The MeshFusion tools within MODO are much more adept at drawing onto the surface, performing a boolean, and keeping a history/tree in order to make adjustments in real time.
I’ve seen people bring this up in the Rhino 6 wishlist topic. Would be an outstanding toolset to see that may open up new territory for the program in all fields of design. Until then I’m either bearing with the repetition and comparative lack of control in Rhino, or taking my booleans to MODO, sacrificing the convenience of NURBS.
Hello, Posting this here, since it’s kind of relevant. During one of our Rhino training sessions in DecodeFablab we had this task to offset srf tapered, so I made this macro for my students. It works on closed polysurfaces only I’m afraid, but hope it helps.
! _ExtractSrf _Pause _Enter
_SetRedrawOff
_SelLast
_Invert
_Lock
_SelSrf
_SetRedrawOn
_OffsetSrf _Solid=No _Pause _Enter
_SetRedrawOff
_SelPrev
_Delete
_SelSrf
_DupBorder
_SetRedrawOn
_OffsetCrvonSrf _Pause _SelSrf _Pause _Enter
_SetRedrawOff
_Delete
_SelCrv
_OffsetNormal _SelSrf 0.01 _Enter
_SelPrev
_Delete
_SelPolysrf
_DupBorder
_SelCrv
-_Loft _Enter _Enter
_SelAll
_CreateSolid
_Unlock
_SetRedrawOn
