As for the extrude curve (command “Fin”), it would make sense to add an extrusion of a surface normal to the srf. For example, I want the surface portion (alpha) is extruded in the direction normal to the entire surface.
It makes sense to ask this?
How would this be different than the Fin command?
I think doing a surface offset with the solid option enabled should do this? (if I understand correctly…)
Yes , split + offset solid.
Perfect Cyver, you are fantastic!
