Extrude Surface Normal to Surface
Extrude Surface Normal.3dm (178.1 KB)
I have not been able to discover the proper sequence to extrude this surface inward normal to the surface by 1 mm so as to create a closed polysurface. Any help would be much appreciated.
Like this?
Try ExtrudeSrf
I’m only seeing one srf and 6 crvs. weird crvs…
I’m not seeing a “normal” direction for that command…
Weird, I can’t see a simple solution. Maybe ‘fin’ in combination with ‘offsetsrf’ and/or offsetnormal?
I thought extrudesrf had a normal direction option …
Assuming ‘offsetsrf’ is using ‘normals’ technology:
Meh, got a weird anomaly there from that approach:
Maybe ‘fin’ the border:
Nope, ‘fin’ has anomaly too:
Yeah I guess Rhino wont automatically trim that data on ‘offsetnormal’ either:
Maybe a loose offset will work idk.
A single surface should not have a crease.
Run DivideAlongCreases, and Explode the resulting polysurface.
Then offset each one and clean up the overlap.
