Offset by 84 fails, but by 55 works…
OffsetCrvOnSrfby84.3dm (24.2 KB)
Hello - as far as I can see an offset of 84 falls completely off the surface.
Correct - the curve is extended - but I would not count on the extended part of curve to always be an offset. The result is always explodable into offsets and extensions.
In this case, since your curve is a line, and the surface planar, the solution is to set a CPlane to the surface, offset the line and extend it. Or, make a Cylinder at 84 radius, using the line endpoints as guides, tall enough to intersect the surface.
Yeah, that’s very clunky. Nothing that can’t be scripted, but I was hoping for some improvement in OffsetCrvonSrf from R4 to R6.
I think the command isn’t “smart” enough as if it “thinks” the offset curve falls over the opposite edge of the surface while in this case it’s simply off to the side.
Just dawned on me - another solution would be to offset in 2 or 3 steps… Probably less screwery would be involved to get to the result too. And it’d work for non-planar surfaces. Thanks for insight!
Here’s a thing that may help if the inputs are simple like your example
import Rhino
import scriptcontext as sc
def test():
rad = 1
if sc.sticky.has_key('CYL_BREP_RADIUS'):
rad = sc.sticky['CYL_BREP_RADIUS']
crvId = rs.GetObject("Select the line", filter=4, preselect=True)
if not crvId:return
srfId = rs.GetObject("Select the surface", filter=8)
if not srfId: return
rad = rs.GetReal("Radius", rad)
if not rad: return
sc.sticky['CYL_BREP_RADIUS'] = rad
crv= sc.doc.Objects.Find(crvId).Geometry
length = crv.GetLength()
plane = Rhino.Geometry.Plane(crv.PointAtStart, crv.PointAtEnd- crv.PointAtStart)
circle = Rhino.Geometry.Circle(plane, rad)
line = Rhino.Geometry.Line(crv.PointAtStart, crv.PointAtEnd)
brep = sc.doc.Objects.Find(srfId).Geometry.Faces[0].DuplicateFace(False)
cyl = Rhino.Geometry.Cylinder(circle, length)
bb = Rhino.Geometry.BoundingBox()
bb.Union(brep.GetBoundingBox(False))
bb.Union(cyl.ToBrep(False, False).GetBoundingBox(False))
line.ExtendThroughBox(bb)
plane.Origin= line.From
cyl = Rhino.Geometry.Cylinder(circle, line.Length)
x = Rhino.Geometry.Intersect.Intersection.BrepSurface(brep, cyl.ToNurbsSurface(), .001)
if x[0]:
ids = [sc.doc.Objects.AddCurve(item)for item in x[1]]
if ids: rs.SelectObjects(ids)
sc.doc.Views.Redraw
test()
