OffsetCrvOnSrf
When I OffsertCrvOnSrf, the resulting curve extends far beyond the original curve I’m attempting to offset. Does anyone have any suggestions?
That command will extend the curve across the entire length of the surface you are drawing on.
Could clean easily by using ExtractIsocurve, snapping to the ends of your fillet, and trimming?
Hello - you can always Explode the output from this command to get the ‘original’ separate from the extensions.
