Hi all,
Using the attached, I am trying to OffsetCrvOnSrf the window vertical edge 100mm aft (towards x-). It fails and I cannot see why. Is it because its not a straight line?
Any workaround?
Thanks as always
Étienne
OffsetCrvOnSrf.3dm (980.7 KB)
Hi all,
Any workaround?
Thanks as always
Étienne
Hi Etienne - it fails here as well, even if the surface is untrimmed - I’ll see if I can figure it out. At the moment it looks buggy…
Thanks for the feedback Pascal,
We will do this manually for now.
Between, thats R5 SR12.
@etienne - for now, run Reparameterize > Automatic on the surface, then offset the curve.
http://mcneel.myjetbrains.com/youtrack/issue/RH-33697
Excellent Pascal,
Thank you very much.
Étienne
