Hi, I haven’t been using rhino for a while and I wanted to pick it up again. I was trying to do an offset command and I don’t know why there are overlapping triangles at the corners. Does anyone know why it doesn’t offset properly as I remember? I tried to click the options on the left side panels but none of them work to make the curve offset properly.
Hello- Offset will do that if the command line option for Trim is set to No.
Ooooh! It works!! DIdn’t realize it was a trimming problem! Thank you xoxo
