Im having trouble with understanding where I’m going wrong in this this parametric beam script i have written.
For the beams i have created the lines i want the geometry to follow and offset them out to each side. for some reason on the top and bottom sections of the beams, some of the lines have offset vertically, not at all or some are perfectly fine.
Now because the issue seems quite inconsistent, I cant figure out what is going wrong here. I have attached the file below, if anyone can help me understand what’s going wrong here, that would be amazing.
ahh so is this just something that can happen when offsetting vs moving things in grasshopper? It can just get lost with the curves direction, a bit like when you offset a curve in rhino and suddenly it has 20x the original control points?
Moving makes much more sense. Amazing thanks for your help!
it probably was something with the curve direction, but I did not take time to look into it any further. although curve direction should not matter for offsetting with a given plane.
this is only a problem, when NURBS curves are offset, as NURBS curve-offsets in general cannot be represented as a NURBS curve witht the properties. so you get an NURBS interpolation of the offset polyline, as this is fast and robust.
How Rhino actually works is kinda hard, as it is not open source, so it is more observation than knowing. Also solving a lot of problems on your own. There is no easy way.
For the actual theory behind Beziér, B-Spline, NURBS the following sites are my favorites:
Honestly i dont know how long the handles on a curve have been a mystery to me. Always wondered how they actually work other then pull this to make curve move this direction. This actually makes so much more sense what im doing when changing the degree of a curve other then make curve smoother haha.
Honestly, thanks for that. I will continue down this rabbit hole for a bit I think!
