Odd things when use Clayoo Bridge tool
Hi
When I use bridge tool in Clayoo. They create odd things as picture below:
I used Bridge/ curve. How can I fix it?
Clayoo - Watering Can - FREE Tutorial.3dm (369.6 KB)
Hi @travis.designer.vn,
Thanks for your question. I can’t see the full bridge on the image but seems very slim in the middle, did you recreate the steps in this video? https://youtu.be/F1anocEDtsM?t=496. Maybe the bridge is not aligned between the selected faces.
From now on I recommend you to report those problems to clayoo@gemvision.com because you will get a better support from a specialized team.
Regards,
Hi @mpcarlos87
Yes, I try replicating this tutorial.
I check Align, it fix problem:
Can you please explain more detail of Align purpose? How it work?
It basically helps to align the faces between you want to “bridge”. It could be used to make a twisted bridge intentionally too. Check the help webpage for more information : http://help.tdmsolutions.com/clayoo/2.5/en/Clayoo.html?ClayBridge.html
Regards,
Thank for your explanation @mpcarlos87
