Objects unintentionally hide in Rhino 9 BETA
On the latest Rhino 9 BETA build (BETA (9.0.26258.12304, 2026. 09. 15.) on my Mac (M1 Max, Sequoia 15.7.5 (24G624)) I’m experiencing objects hiding unintentionally.
They are not deleted, I can show them again. It happens on Save (Cmd+S is tied to !_Save so it shouldn’t do hiding), on switching to other applications (e.g. I Cmd+Tab to my browser and back to Rhino, I routinely need to run Show to get back to where I was).
An example from the command history:
Command: Save
File successfully saved as Rhino 9 file file_path/model.3dm.
551 objects hidden.
I didn’t run the hide command but objects hide nonetheless. :melting_face:
Any ideas on how to investigate what’s happening?
Thanks!
You can record your screen to Show your problem and run systeminfo command and paste the result here that way developers could see your problem much better
Screen recording:
SystemInfo:
Rhino 9 SR0 2026-9-15 (Rhino 9 BETA, 9.0.26258.12304, Git hash:master @ c3d10428b087d6fe48c7db5ecea508f0cce7a6e5)
License type: Commercial, build 2026-09-15
License details: Cloud Zoo
Expires on: 2026-10-30
Apple macOS Version 15.7.5 (Build 24G624) (Physical RAM: 64GB)
Mac Model Identifier: MacBookPro18,2
Language: en-GB (MacOS default)
.NET 10.0.2
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
Color LCD (2056 x 1329 @ 120.00Hz)
GPU Vendor: Apple
USB devices
WIBU-SYSTEMS AG: CodeMeter-Stick
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftDataDetection.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswift_math.dylib
/usr/lib/swift/libswift_signal.dylib
/usr/lib/swift/libswift_stdio.dylib
/usr/lib/swift/libswift_time.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftunistd.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/fb/.rhinocode/py313-rh9/libpython3.13.dylib
/Users/fb/.rhinocode/py313-rh9/lib/python3.13/lib-dynload/grp.cpython-313-darwin.so
/Users/fb/.rhinocode/py313-rh9/lib/python3.13/lib-dynload/zlib.cpython-313-darwin.so
/Users/fb/.rhinocode/py313-rh9/lib/python3.13/lib-dynload/_bz2.cpython-313-darwin.so
/Users/fb/.rhinocode/py313-rh9/lib/python3.13/lib-dynload/_lzma.cpython-313-darwin.so
/Users/fb/.rhinocode/py313-rh9/lib/python3.13/lib-dynload/math.cpython-313-darwin.so
/Users/fb/.rhinocode/py313-rh9/lib/python3.13/lib-dynload/_bisect.cpython-313-darwin.so
/Users/fb/.rhinocode/py313-rh9/lib/python3.13/lib-dynload/_random.cpython-313-darwin.so
/Users/fb/.rhinocode/py313-rh9/lib/python3.13/lib-dynload/_opcode.cpython-313-darwin.so
/Users/fb/.rhinocode/py313-rh9/lib/python3.13/lib-dynload/_ssl.cpython-313-darwin.so
/Users/fb/.rhinocode/py313-rh9/libssl.3.dylib
/Users/fb/.rhinocode/py313-rh9/libcrypto.3.dylib
/Users/fb/.rhinocode/py313-rh9/lib/python3.13/lib-dynload/_socket.cpython-313-darwin.so
/Users/fb/.rhinocode/py313-rh9/lib/python3.13/lib-dynload/select.cpython-313-darwin.so
/Users/fb/.rhinocode/py313-rh9/lib/python3.13/lib-dynload/array.cpython-313-darwin.so
/Users/fb/.rhinocode/py313-rh9/lib/python3.13/lib-dynload/_struct.cpython-313-darwin.so
/Users/fb/.rhinocode/py313-rh9/lib/python3.13/lib-dynload/binascii.cpython-313-darwin.so
/Users/fb/.rhinocode/py313-rh9/lib/python3.13/lib-dynload/_datetime.cpython-313-darwin.so
/Users/fb/Library/Application Support/McNeel/Rhinoceros/packages/9.0/BlockEditNew/2.1.7/blockeditnew.rhp	"BlockEditNew"	2.0.0.0
/Users/fb/Library/Application Support/McNeel/Rhinoceros/packages/9.0/ObjectOutliner/0.9.2/net7.0/ObjectOutliner.rhp	"ObjectOutliner"	0.9.2.0
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework	"Renderer Development Kit"	9.0.26255.1001
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp	"Commands"	9.0.26258.12304
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp	"Snapshots"	9.0.26255.1001
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp	"RDK_EtoUI"	9.0.26258.12304
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp	"MeshCommands"	9.0.26258.12304
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp	"Rhino Render"	9.0.26258.12304
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp	"RhinoCycles"	9.0.26258.12304
/Applications/RhinoWIP.app/Contents/PlugIns/SectionTools.rhp	"SectionTools"	9.0.26255.1001
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp	"Displacement"	9.0.26255.1001
/Applications/RhinoWIP.app/Contents/PlugIns/3DxRhino.rhp	"3DxRhino.9"	9.0.26255.1001
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp	"PanelingTools"	9.0.26255.1001
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp	"IronPython"	9.0.26258.12304
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp	"Grasshopper"	9.0.26258.12304
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp	"RhinoCodePlugin"	9.0.26258.12304
I would try blocking BlockEditNew and ObjectOutliner just to verify that those aren’t factoring into what you are seeing. You should restart after blocking plugins.
Disabling the ObjectOutliner plugin seems to be the fix. Thanks for the reminder @stevebaer!
@9dpbQ can you please take a look at it?
Hello, and thank you for the detailed report and screen recording.
This issue is most likely caused by Object Outliner’s Isolate-state restoration.
While the issue is occurring, could you please run the Unisolate command and check whether the objects still become hidden after saving or switching applications?
I was also able to reproduce the issue in my environment. When an Isolate state is active, if I use the Show command to make other objects visible and then switch applications, those objects are hidden again.
This behavior is not quite what I intended, so I plan to fix it in an upcoming update.
I installed ObjectOutliner again (0.9.2), restarted Rhino, opened the file in question, then ran Unisolate . I tried a few things (saving, switching windows, showing-hiding stuff): it seems to resolve the hiding problem, thanks!
