Objects permanently hidden
I’ve encountered a very strange bug… objects exist, but can’t be selected, seen or edited in anyway. And I’ve tried everthing… I mean everything. I was working in a large file, with other files worksessioned into it, and using a combination of layer states, hide and isolate to control visibility. I went through some diagonstics (with help from Claude)…
Some objects in the file become permanently invisible and unselectable. The symptoms are:
  • Objects exist in the document — doc.Objects.Count reports them, layer deletion warns about objects on the layer, and a Grasshopper Geometry Pipeline component can access their geometry
  • All object attributes appear completely normal — Mode is Normal, Visible is True, ViewportId is empty, layers are on and unlocked, IsHidden and IsLocked are both False
  • _Show, _Unisolate, _SelAll find nothing
  • IsSelectable() returns False with no attributable cause
  • The condition survives SaveAs to a new file
  • Opening in Rhino 9 WIP does not resolve it
  Audit:
  Document Manifest:
  Texture Mapping: 3 active, 1 system.
  Material: 1783 active, 2 system.
  Line Pattern: 2 active, 3 system.
  Layer: 40 active, 1 system.
  Group: 39 active.
  TextStyle: none.
  Annotation Style: 3 active, 12 system.
  Light: none.
  Hatch Pattern: 1 active, 9 system.
  Block: 6 active.
  Model Geometry: 7170 active.
  Total: 9047 model components. 28 system components.
  Audit Summary:
  Table tally:
  40 layers
  6 instance definitions
  3 annotation styles
  0 fonts
  2 linetypes
  1783 rendering materials
  Object tally:
  3213 normal objects
  0 locked objects
  0 hidden objects
  0 deleted objects (in undo buffer)
  3957 block definition objects
  0 reference normal objects
  0 reference locked objects
  0 reference hidden objects
  0 reference block definition objects
  No errors.
system info:
  Rhino 8 SR30 2026-4-13 (Rhino 8, 8.30.26103.11001, Git hash:master @ 3ad61623b0ac4561e2f13265580c56a9f50596d8)
  License type: Commercial, build 2026-04-13
  License details: Cloud Zoo
  Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 63GB)
  .NET 8.0.26
  Computer platform: LAPTOP  - Plugged in \[100% battery remaining\]
  Primary display: DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 7-29-2025 (M-D-Y).
  > External USB display device with 3 adapter port(s)
  * Secondary monitor attached to adapter port #0
  * Windows Main Display attached to adapter port #1
    Primary OpenGL: NVIDIA GeForce RTX 5070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 9-22-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.42
  * Video pass-through to primary display device
  Secondary graphics devices.
  > External USB display device with 0 adapter port(s)
  * There are no monitors attached to this device. Laptop lid is probably closed
    Intel(R) Arc(tm) 140T GPU (32GB) (Intel) Memory: 2GB, Driver date: 10-13-2025 (M-D-Y).
  * Secondary monitor is laptop's integrated screen or built-in port
  OpenGL Settings
  Safe mode: Off
  GPU Tessellation is: On
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 9-22-2025
  Driver Version: 32.0.15.8142
  Z-Buffer depth: 24 bits
  Total Video Memory: 8151 MB
  C:\\Users\\aschiffer\\AppData\\Roaming\\McNeel\\Rhinoceros\\8.0\\Plug-ins\\RookNative\\RookNative.rhp	"RookNative"
  C:\\Users\\aschiffer\\AppData\\Roaming\\McNeel\\Rhinoceros\\packages\\8.0\\Corgi\\0.8.6\\net7.0\\Corgi.rhp	"Corgi"	0.8.6.0
  C:\\Program Files\\Enscape\\Enscape.Rhino.Plugin-net48\\Enscape.Rhino8.Plugin.dll	"Enscape.Rhino8.Plugin"	4.8.0.723
  C:\\Users\\aschiffer\\AppData\\Roaming\\McNeel\\Rhinoceros\\8.0\\Plug-ins\\RookNative\\Rook.rhp	"Rook"	1.2.3.0
  C:\\Program Files\\Rhino 8\\Plug-ins\\Commands.rhp	"Commands"	8.30.26103.11001
  C:\\Program Files\\Rhino 8\\Plug-ins\\rdk.rhp	"Renderer Development Kit"
  C:\\Program Files\\Rhino 8\\Plug-ins\\AnimationTools.rhp	"AnimationTools"
  C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoRenderCycles.rhp	"Rhino Render"	8.30.26103.11001
  C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoRender.rhp	"Legacy Rhino Render"
  C:\\Program Files\\Rhino 8\\Plug-ins\\rdk_etoui.rhp	"RDK_EtoUI"	8.30.26103.11001
  C:\\Program Files\\Rhino 8\\Plug-ins\\NamedSnapshots.rhp	"Snapshots"
  C:\\Program Files\\Rhino 8\\Plug-ins\\MeshCommands.rhp	"MeshCommands"	8.30.26103.11001
  C:\\Program Files\\Rhino 8\\Plug-ins\\IronPython\\RhinoDLR_Python.rhp	"IronPython"	8.30.26103.11001
  C:\\Program Files\\Rhino 8\\Plug-ins\\RhinoCycles.rhp	"RhinoCycles"	8.30.26103.11001
  C:\\Program Files\\Rhino 8\\Plug-ins\\Toolbars\\Toolbars.rhp	"Toolbars"	8.30.26103.11001
  C:\\Program Files\\Rhino 8\\Plug-ins\\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\\Program Files\\Rhino 8\\Plug-ins\\Displacement.rhp	"Displacement"
  C:\\Program Files\\Rhino 8\\Plug-ins\\Calc.rhp	"Calc"
  C:\\Program Files\\Rhino 8\\Plug-ins\\SectionTools.rhp	"SectionTools"
  C:\\Users\\aschiffer\\AppData\\Roaming\\McNeel\\Rhinoceros\\packages\\8.0\\PanelingTools\\2024.8.20.677\\PanelingTools.rhp	"PanelingTools"
I will upload the file, as I can’t share it publicly.
I’m truly stumped. maybe @pascal ? Any help would be much appreciated.
Can you share an example file with mcneel privately?
https://www.rhino3d.com/upload if so please put a link to this thread in the comments
Thanks Japhy. I just uploaded.
There are number of layers that have the Model On toggled off.. are those the objects you are referring to or are there others?
so sillly! literally the dumbest thing. Should have checked that, obviously.
Thank you.
