to reproduce: create 2 objects, isolate one, then move or change anything on it, call Unisolate. it forces one to use show, which then shows all the prior actually unwanted, hidden objects.
Hi -
When I do exactly that in a new file, the object that was hidden with the Isolate command is made visible again.
Mac 7.3.21010.21002
is that a relase canditate? i have the regular recent update running.
edit: oh no wait i think i updated to a candidate
That one is a bit older than the current public release candidate, which is 7.3.21012.11002.
i am confused, are you using a windows version which is higher than mac?
i have 7.2.21005.13002, 2021-01-05 which is supposed to be a candidate version.
The latest public Service Release on Mac is 7.2 - 7.2.21012.11002.
The latest public Service Release Candidate on Mac is 7.3.21012.11002.
Both were released about 13 hours ago.
i have set it to release candidate and it gives me that
well nevermind, i cant risk updating anyway right now
guys this keeps happening frequently, unisolate does not seem to work very reliable, it often gets stuck mostly when i recall correct after using cmd z or something very similar and equally simple. then i am left with an isolated object with Rhino telling me that no objects are hidden, which can only be reverted by unhiding all the hidden objects which then of course is a total mess to sort that out again.
@wim can you maybe have a closer look at this?
here a topic claiming the same issue
and here some issues with unisolate.
Hi -
The video in one of the topics that you linked to showed a reproducible workflow that triggers this. I then found that the issue has been on the pile as RH-57579 and added all threads.
Thanks,
“Unisolate” command keeps acting buggy in my Rhino v.7 SR38 (7.38.24338.17001, 2024-12-03) on Windows 10.
In a medium complexity model I’m working on, all of a sudden it stopped showing hidden objects: the only way to get back the hidden objects was to use “Show” command.
Hi Gianpietro -
If you can provide the steps to reproduce this, I can see if that happens in Rhino 8.
As soon as I find 5 minutes I’ll try to give you as more information as I can on the behaviour!
Hi Wim,
I tried many times yesterday, but I was unable to reproduce the bug in a controlled situation yet, unluckily.
At the moment I can just say that sometimes it happens in Rhino 7.
I can add I’m using two displays, with different resolutions, and that I was working on the secondary one with a custom tool collection I made for myself, the toolbar being on the secondary display.
If I encounter this problem again I will try the best to send you some more info.
Thank you
