I am working on a tool to extract clippingplane info to automate a 2D section drawing tool.
And I see that if I select the extracted clippingplane object then I can not see the selection since the edge of the selected object is drawn BEHIND the “Show edge” edge in OpenGL.
Can this be fixed please? So it is easy to see selected objects?
Default with “Show fills” turned off so I don’t get the interference
And here with “Show Edges” turned off as well:
I would prefer if “ShowFills” were drawn behind objects ON the clipping plane as well if that is possible.
