Objects disappear inside block in shaded mode.
Usually occurs while I create many sub blocks.
Is there any way to fix that?
Block Disappear.3dm (403.7 KB)
Hi -
Please run the Rhino SystemInfo command and copy-paste the result here.
Hi wim, it’s the SystemInfo result:
Rhino 7 SR24 2022-10-17 (Rhino 7, 7.24.22290.19001, Git hash:master @ 54c30423a44610f6e1eaf359177ebcac4a5be4ed)
License type: Commercial, build 2022-10-17
License details: Stand-Alone
Windows 10 (10.0.19042 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1660 SUPER (NVidia) Memory: 6GB, Driver date: 10-6-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 522.25
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-6-2022
Driver Version: 31.0.15.2225
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22094.1322
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 7\Plug-ins\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Users\liu.tong\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.24.22290.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.24.22290.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.24.22290.19001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.24.22290.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.24.22290.19001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.24.22290.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.24.22290.19001
Hi -
Thanks - that looks like that ought to work.
Does this happen with any file or is this file-specific?
It happen with any file.
It’s work fine at first.
Usually happend after I create many levels of sub blocks. ex: 100+kinds of block in this rhino file. And some blocks are inside other blocks. These block which has many levels of subblock will disappear, other blocks are display normally.
If I explode these subblocks inside the block, it will display normally too.
Hi -
That does sound like somewhat file-specific.
Can you post a file here, or, if it can’t be public, upload it on Rhino - Upload to Support with reference to this thread?
Block Disappear2.3dm (893.0 KB)
I copy the disappear block out to a single file. The belower block cannot display in shader mode. I have to explode the block to show it.
Hi -
I can see this in the file that you posted and in a simplified version of that file:
I can’t, however, recreate this from scratch in a new file. I see there is 3rd party plug-in data attached in your file and wonder if you can reproduce this behavior in a new file without any such plug-ins loaded?
You can also simply remove transparency from the layer color of layer “2” - that will make all objects visible in shaded mode.
