Block issue in ghosted mode
I’m having an issue in rhino when I create a block. The appearance in ghosted mode changes and darkens the same closed polysurface if it is a polysurface within a block vs a simple polysurface. It’s somewhat benign, but because it’s darker and grayed out it sort of makes the block appear locked compared to other items. Has anybody else experienced this?
The above image shows what is happening. The 1st and 3rd polysurfaces are exploded and not within a block while the 2nd a 4th are identical polysurfaces within a block.
Hi John,
Please run SystemInfo command in Rhino and post the result. A small example file is usually helpful as well. Thanks!
Rhino 8 SR17 2025-3-7 (Rhino 8, 8.17.25066.07001, Git hash:master @ b14fcd901289f8715631debb308bc919a4988e07)
License type: Commercial, build 2025-03-07
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4060 Ti (NVidia) Memory: 8GB, Driver date: 3-14-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.83
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-14-2025
Driver Version: 32.0.15.7283
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\SimLab\Plugins\SimLab USDZ From Rhino\SimLabUSDZExporter.rhp “SimLab USDZ Exporter”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
example file.3dm (1.2 MB)
I believe this was fixed in 8.18, please update and try again.
Huh, strange, when did that update come out? The automatic updates on my Rhino said I was up to date even though I was only running 8.17
It still a release candidate
Hi John -
New Service Releases are published every second Tuesday of the month and Service Release Candidates for the next version every Tuesday.
This particular issue was fixed in 8.18 which became the current SR two days ago.
Sometimes it takes a restart or two of Rhino for it to find the update. If all else fails, you can use the link on the Updates and Statistics page to manually download and install the update.
