Bug in block edges invisible
Hi there,
I switched from Rhino 5 to 6 this week. It is great, goog job!
Now I came across the following problem:
All my outer line of the 3D Solids are gone the moment I created a block and edited it.
It looks like this:
When I open the block it looks like this:
I use a variation of the shaded mode.
Can anyone please help?
Thanks in advance
Liis
Hello- can you please run the SystemInfo command in Rhino and post the results here?
Rhino 6 SR8 2018-8-28 (Rhino 6, 6.8.18240.20051, Git hash:master @ d037927543424e8b3ce54e46b435866178a6349c)
Licence type: Evaluation, build 2018-08-28
License details: Stand-Alone
Expires on: 2018-12-09
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
AMD RADEON R9 M395X (OpenGL ver:4.5.13476 Compatibility Profile Context 22.19.170.1536)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50
Driver Date: 7-20-2017
Driver Version: 22.19.170.1536
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.8.18240.20051
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.8.18240.20051
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.8.18240.20051
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.8.18240.20051
Hello - does the default shaded mode look correct?
No, unfortunately it does not.
Could you post the file so that we can try to reproduce this?
I drew the object again and created a new block and the bug was gone. Unfortunately I overwrote the file and can’t reproduce it.
Should the bug come forward again, I will post the file immediately for you.
Till then: Thank you.
