Hi guys,
I have a mysterious issue in rhino 7, as you can see in the picture, the objects that are visible in the perspective view, are invisible in the other 3 views?
Thanks for helping
greets
Hi guys,
Thanks for helping
greets
Hi Marcus -
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR27 2023-2-1 (Rhino 7, 7.27.23032.13001, Git hash:master @ 4a0030c0d354560df03764f4f49ecc5d119e5118)
License type: Educational, Build 2023-02-01
License details: Stand-Alone
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 11-3-2021 (M-D-Y). OpenGL Ver: 4.6.0 - Build 30.0.101.1029
- Windows Main Display is laptopâs integrated screen or built-in port
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 30.0.101.1029
Driver Date: 11-3-2021
Driver Version: 30.0.101.1029
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp âCommandsâ 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp âRenderer Development Kit UIâ
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp âIronPythonâ 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp âGrasshopperâ 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp âDisplacementâ
Donât ask me what causes the problem but the Z-Standort is way off.
Try the command _Zoom _All _Extents
You might be able to use the shortcut âZEAâ
Can you post the Grasshopper definition?
Try running 4View twice to reset all viewports and then zoom all extents.
Thanks a lot dude, solved it!
greets
