Hello, everyone,
I currently encounter a situation as follows:
I want to reorder the vertices on the selected object
I first set a fixed point and then compare the distance between the
vertex on the object and the fixed point
But when I select the number amount <5, everything is normal
But when the number amount > 5, because the objects are arranged in a
ring, the order is chaotic
Can someone please tell me a better solution
thank
Object arrangement problem.gh (25.5 KB)
shackleton
(Sir Ernest Shackleton)
April 12, 2020, 6:07am
2
Hello sailor!
I’m sorry but your script has a component called ‘curve middle’ wich I do not have and I can’t find online. Would you replace it or post the link to this plugin website?
Best regards,
Hi Sir Ernest Shackleton,
This is the built-in plugin for rhino 6.0 grasshopper
shackleton
April 12, 2020, 7:31am
4
Weird, that component does not appears in my GH. Anyway, here’s my solution:
CONVEXHULLING.gh (32.3 KB)
If this helps you solve your problem, mark it as solution. Thanks.
Best regards,
Please forgive my wrong expression
I ended up hoping to rearrange the order of triangle vertices
As shown below!
