I have this code to place a Rhino geometry in a form of a box, in Revit as a mass. The code works other than the object does not seem to be placing in the same place in Revit as it does in Rhino. I want the object to place as it does in Rhino. The origin is set to 0, 0, 0 as highlighted by the red circle. Any help?
can you post a internalized grasshopper file? Thanks
I actually just figured it out. I was facing the other way in my rhino screen. Just a quick simple fix and the problem was solved. I was just not thinking!!!
ooh, that would do it, it was a bit of a puzzling, your definition looked fine.
