Thanks for your swift reply, Japhy.
Here is the Rhino about info.
I have used the CTRL + Shift to open without any revit plugins-nothing loads. However, i get the same dialogue box appearing. If i choose the same options, it opens yet another session of revit (2024).
I did run system/Info. (See below)
Rhino 7 SR37 2024-4-16 (Rhino 7, 7.37.24107.15001, Git hash:master @ d2e42f70b9d3aa58f6053e2998a0db2abcd7555b)
License type: Commercial, build 2024-04-16
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro T2000 (NVidia) Memory: 4GB, Driver date: 6-23-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.59
Secondary graphics devices.
Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 3-3-2022 (M-D-Y).
> Integrated graphics device with 0 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-23-2022
Driver Version: 31.0.15.1659
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\AOh.MSP\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “SpeckleConnectorRhino” 2.19.1.15397
C:\ProgramData\Beam\App\RHINOBEAM.dll “MKS BEAM” 1.10.1.1
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.24138.1238
C:\Program Files\SimLab\Plugins\SimLab USDZ From Rhino\SimLabUSDZExporter.rhp “SimLab USDZ Exporter”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.37.24107.15001
I have turned off every addin in grasshopper. I am using the cage and CageEdit to manipulate a simple box, and push this to revit. I am getting this, every time i move a point on the cage.
I have just attempted to tab to a 3d view and received this:
Thanks for your help thusfar.
Not sure what is happening. As you can see, it is just a simple box.
Regards
Aindrias
