Hi
Thanks for Rhino 8, it’s awesome.
I have a funny behavior on an OBJ file, which maps the texture incorrectly once opened with Rhino 8.
Rhino 7 opens the same file with the correct textures and the 3dm file looks as expected.
This is the same on a Macos and Windows machine.
Is this a know behavior?
Greetings, Chris
wim
(Wim Dekeyser)
February 13, 2024, 1:50pm
2
Hi Chris -
Chris-K:
No. Please run the Rhino SystemInfo command and copy-paste the result here.
Hi and sorry for the late reply.
Please see the output below.
It seems that it had an effect if I had the OBJ files that I wanted to import, located inside the iCloud or on a “normal” drive.
I was able to repeat it on my Mac back then. I then had that issue in Rhino 7 as well.
Please still see the output of the systeminfo:
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13002, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Commercial, build 2024-03-12
License details: Cloud Zoo
Apple macOS Version 14.4 (Build 23E214) (Physical RAM: 36GB)
Mac Model Identifier: Mac15,10
Language: en-US (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M3 Max
SAMSUNG (1920 x 1080 @ 60.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp "MeshCommands" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp "BlockEdit" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp "Rhino Render" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp "AnimationTools" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/NamedPositions.rhp "Named Position" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp "SectionTools" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp "Legacy Rhino Render" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoBonusTools.rhp "Rhino Bonus Tools" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_ACAD.rhp "AutoCAD file export : export_ACAD" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp "Displacement" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_ACAD.rhp "AutoCAD file import: import_ACAD" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp "SolidTools" 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp "RhinoCodePlugin" 8.5.24072.13002
