Edit: See WIP results far below.
OK, so I have a simple mesh, which is “manually” welded at 180 degrees in Rhino, and the I export it as is from Rhino5 with File | Export Selected
. Testing that mesh with MeshMixer “Inspector
” command, that looks fine (leftmost screenshot).
But if then I check the option Welded (see fig 2)
Fig.1. a). Rhino all options cleared (=OK). b.) “Welded” is checked (not OK!), and c). My .obj-export component calling mesh.Weld(180)
before export (OK).
Fig. 2. Export options (no options but “Welded” in case b above:
If I tick the red ball in MeshMixer, the res surfaces are remove altogether leaving “strange surfaces” behind.
Fig 3. After “repair” (ticking the red ball) in MeshMixer:
In short, if first welding manually with the Rhino menu command mesh.Weld(180)
, and leaving the mesh “Unmodified” on export, this problem doesn’t occur.
Edit:
Edit 2: I tested this also in WIP, and WIP [doesn’t either] export a valid mesh even when checking the option “Welded
”. The exact difference in the obj ouput file produced by Rh5 and Rh6 is shown in this diff (Rh5 to the left).
Fig.4 Diff Rh5 and Rh6:
And the bad (wip) result:
// Rolf
Edit: Modified the header.
