When exporting from Rhino to OBJ, meshes seem to always be merged by material, regardless of layers, groups, objects, etc. You can test by importing the OBJ back into Rhino.
This is troublesome when I need to work with the meshes individually in other software but keep the same material.
Other formats like Collada preserve the meshes, but I prefer to work with OBJ/MTL. Is there some setting or export option that I’m missing?
do you mean welded or what do you mean by merged? did you read through the obj export options? and are you sure they are not just grouped as via the import options? have you got an example file or a screen shot and can explain maybe in detail with this?
