Nudge do not "undo"
I just installed Rhino 8 for Mac. Undo for nudge doesn’t seem to work. Also, I can’t grab points and drag. It drags the whole object [a dimension object] instead. Is this a bug?
Hi Darryl - nudge should undo unless the stuff being nudged is so large that it takes up all the undo memory.
Hello Pascal, It just doesn’t work. Command feedback just says nothing to undo. I am nudging individual dimension objects’ handles. for the specs of the machine I’m running Rhino8 on, I have 32 GB of memory on my MacBook Pro 2019.
Hi Darryl - if you make a box and nudge it, in a new file, does the Undo work? Can you post a file with objects that do not?
Hello Pascal, Right after I reported this, the file crashed Rhino8. After opening it again, everything works… It may have been something with a file that has been created with Rhino6 carried onto 7 and now 8. I’ve also purged the file and saved it again. Thank you.
