If I do not want the NOTES panel to import the block info everytime I open the file, how do I turn that off?
Bumping this Q.
To make sure I am clear, my notes panel loads block data that has been imported clogging up the panel. Is this an option that can be turned off, when blocks are imported their info do not get pasted into notes panel?
I think you need to be more precise about what you are doing
my guess is that you mean you are importing some other file format into rhino, and that the importer for that format is putting stuff in your notes
yes that is what I mean, thanks.
not a big deal but would be nice to turn off.
Hi Clint - is the incoming file in iges format?
Pascal,
Usually they are Solidworks. Let me confirm next time I see it.
