I started using Rhino 6, and found out that when I want to move or copy something, it doesn’t show where I want to move the object to. I attached some pictures and hope you guys can help me out with this issue. It worked well in Rhino 5.
I’m not sure what you are describing. Is it the SmartTrack
that is getting in the way? Please post a file with as few objects as possible and marked with points where you are clicking and snapping.
I want it to be vibsible like this. I can use this in another file so maybe there is something wrong with the file I am working on? Do you see the yellow object that is want to move, it is like it is not visible in the other file.
maybe is just a camera problem, if you have a large scene, try with zoom selected before copy.
Some objects work in the same file while others won’t work. So I think there is something wrong in the file but I will try to copy it into a new file.
I’ve been experiencing the same problem, has there been any further developments on this issue?
Hello - none that I know of - if you have a file that shows the problem, please post it or send to tech@mcneel.com with a link back to this topic in your comments. Please also run SystemInfo
in Rhino and Copy/Paste the results here.
