Not on Trusted Service
I’ve had a report that some of the Geometry Gym Plugins don’t load in Rhino Inside Revit.
I tried installing ggRhinoRobot from package manager into Rhino8, started Revit 2024.
There is a message about plugin “Not on Trusted Service”.
If anyone has any suggestions on how to avoid this issue, I’m grateful. Loads fine when not running inside Revit.
Thanks,
Jon
Hi @jonm,
If you are loading assemblies from remote source you may need to tell your users to tweak the Revit.exe.config file.
Please see loadFromRemoteSources.
Thanks for the reply.
There is no remote service involved to my knowledge. Package manager deploys the plugin to the equivalent of C:\Users\JonMirtschin\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\ggRhinoRobot\24.10.13.8
I tried appending the config file as per your instruction, but it change anything.
Can you please try installing the plugin and see if it loads for you?
Thanks,
Jon
Sorry, I’ve attached a debugger to the revit instance, and can see the issue is mine.
I’m rebuilding the plugin to resolve this. Thanks for taking time to respond.
