Not getting smooth loft
I am not able to make a smooth loft over 3 ellipse curves I made on Rhino 8. How do I resolve this??
Can you drop the 3dm file?
Sure,
ellipse.3dm (48.6 KB)
No problem creating it at all, though this is not ideal setup for loft command.
loose
normal:
this is what your linework shows:
Can u attach this Rhino file for me?
I have recreated the issue by following your settings.
That error appears when ground plane is on (something you should report to McNeel)
Can you please attach the file you created for my reference?
Sure
ellipse.3dm (184.9 KB)
@CM_Adithya any particular reason you’re still on Rhino 8.1? You’re missing out on a year worth of updates and fixes. 8.13 will go out in a couple of days.
Also, your model is pretty far from origin. Moving it to around origin should fix the weird surface issue as well.
