Normal vector
Hello, I’m trying to get the normal vector of a point that is the intersection between mesh/ray.
To do it I did a custom component in C++ that obtains the intersection point and another custom component with GetClosestPoint() Rhino C++ API: ON_Mesh Class Reference that obtains the m_face_index.
Now with the intersection point and the face index, is there any function to get the normal?
Thank you!
You need two components. First Mesh Closest Point, then Mesh Eval.
Thank you Martin, this was so usefull to understand what I want to do.
Now my problem is I don’t find a function to create a custom component like MeshEval. Do you know any function that can help me?
Thanks again!!
Why do you need a custom component?
I’m trying to replicate raytracing for optical simulations using C++. It’s for an university work and I must do as much as possible with code, even if there are already components that do the same that I want.
I recategorized your topic to “Grasshopper Developer”. You might get better help that way.
Thanks Martin
In C# I use that
for this kind of simulation I think surface are better than meshes.
if you want mesh
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Intersect_Intersection_MeshRay.htm
/// <summary>
  /// </summary>
  /// <param name="surface"></param>
  /// <param name="ray">A line that is oriented so the ray is going to from to the end</param>
  /// <param name="distanceMax">The max distance we look for relexion</param>
  /// <param name="tolerance">Tolerance</param>
  /// <returns>The line representing the reflexion, line.From is on surface</returns>
  public Line RaySurfaceReflexion(Surface surface, Line ray, double distanceMax, double tolerance)
    Line lineRay = new Line(ray.From, ray.Direction, distanceMax);
    Line lineOut = Line.Unset;
    Curve curve = lineRay.ToNurbsCurve();
    CurveIntersections cis = Rhino.Geometry.Intersect.Intersection.CurveSurface(curve, surface, tolerance, tolerance);
    if (cis.Count > 0)
      double minParameter = double.MaxValue;
      foreach (IntersectionEvent ci in cis)
        if (ci.ParameterA < minParameter)
          minParameter = ci.ParameterA;
      if (minParameter >= 0)
        Point3d pointIntersection = curve.PointAt(minParameter);
        double u, v;
        surface.ClosestPoint(pointIntersection, out u, out v);
        Plane frame = Plane.WorldXY;
        surface.FrameAt(u, v, out frame);
        Vector3d reflexion = Reflexion(ray.Direction, frame.Normal);
        lineOut = new Line(pointIntersection, reflexion, 1);
    return lineOut;
  /// <summary>
  /// Perfect relexion
  /// </summary>
  /// <param name="ray">Ray as a vector</param>
  /// <param name="normal">Normal Vector at the impact point</param>
  /// <returns></returns>
  Vector3d Reflexion(Vector3d ray, Vector3d normal)
    normal.Unitize();
    return ray - 2.0 * (ray * normal) * normal;
