Need some help with the process and tools to use in creating a “draped ring” of aluminum sheet. I expect its simple but still new to Rhino and uncertain if the distortion is best done in planar or solid mode. <a class=“attachment”
Not sure what you mean by “mode”. Is this a concept you’ve encountered in other software? In Rhino a solid is simply a closed (poly)surface, and is defined by its surface(s).
Two approaches if you want a solid:
Create a single surface with the desired shape, and then use OffsetSrf to create a solid.
Create the solid directly using an extrusion or sweep command.
Several different ways to create “distorted”/warped surfaces and solids:
Create curves with the desired shape, and then create the surface/solid using those curves.
Create a planar surface and alter its shape by moving control points.
I concur with Arnaud’s recommendation of using CageEdit. Note that CageEdit can use surfaces, curves and other objects as the control object, not just simple solids.
Generally you want to reduce the number of control points which need to be moved to the minimum possible, and CageEdit is a great tool for doing so.
Luckily I still had the file open, here you go: Ring.3dm (107.0 KB)
You might want to copy the face border and rebuild the curves with fewer and more equally spaced points then sweep with 2x rails etc to rebuild the surface.
