Hi guys i’m new in the mesh modeling world in rhino and i’m stuck with this problem: how can i plug this hole when i split the mesh? i tried to create some patch between correspondents edges top-down the model and then i “quadremesh” it i still got some tiny holes in the mesh. is there another workflow that i miss? I would like to achive two parts that i can print in my small 3d printer. Any help is gratefully received
I would subtract a thin piece maybe 0.2 mm thick instead of splitting the mesh.
Use the mesh boolean difference command.
_MeshBooleanDifference
I had to run _SplitDisjointMesh afterwards to split the mesh in its two pieces.
Both meshes are closed
subtract-dontsplit.3dm (8.0 MB)
thanks man i was hoping for a quick shortcut like that
