Help With Halloween Meshes
Hello all, I’m looking for some help working with meshes. I’m normaly a cabinet and woodworking engineer so I’m not used to working in meshes.
I’m trying to create a “helmet” of Tim Curry’s Darkness from 1984’s Legend.
I’ve scanned my own head, scaled and located it as well as someone’s sculpture of the Darkness. I’m having a hard time thickening the Darkness mesh (ideally ~1/4", I’d like it mostly hollow and then I can pack it with foam) and possibly connecting it to the offset mesh I’ve made of my own head. If I was able to solidify the helmet as it currently exists I’d be happy to boolean out the offset of my own head.
I recognize the issue is probably lying with the mesh being not intended for this purpose as when I repair mesh it throws lots of issues but none I know how to actually attack or fix.
I would love some direction in my workflow. I’m a little out of my depth but looking to improve. I’m sure I’ll require further clarification but I couldn’t find any other posts dealing with a similar topic. Thank you!
Halloween_Small.3dm (16.2 MB)
This is the kind of thing that historically would take an age, but you can just shrinkwrap it now. Are you using Rhino 8? If you run an interpcrv around the open base and patch it, you can get the gaps close enough.
I’ve uploaded an obj due to filesize/not sure what version you’re on, and you may need to remove some material to get it to fit properly, but it’s mostly there.
See Kyle’s tutorial for the shrinkwrapping;
Legend.obj (16.2 MB)
ya beat me to it!
use splitdisjointmesh command to make that file into a individual parts instead of one big mesh.
This tutorial is excellent! Exactly what I needed. I’m on Rhino 8 btw.
So the issue I’m running into now is when I try and shrink wrap it, I get these results
If I turn of inflate vertices or fill holes, I get nada, obviously this to me says that my mesh needs repairing, remeshing, hole filling etc.
But when I try to run literally any of the repair options I see for addressing this, I get a result like this:
or something like it. My mesh is still in there, and I’ve adjusted my display settings to be slower and smoother and of highest detail.
I appreciate your work @Dipso, I will poke at that for while to give myself a break from the headscratching. I’m confused as to how you got this result as I followed Kyle’s tutorial as simple as it was.
Hot tip! my issue is that when I splitdisjointmesh it doesn’t actually break the mesh up. It says it does but none of the individual items are selected. It says 1 Mesh split into 68 mesh and I can’t seem to get at the horns to remove them. The horns convert to .step easily and I’ve already largely set them up to print.
I tend to keep the inflate/fill holes options unchecked, and keep the target edge length slightly larger than any holes, but this will vary depending on the units/scale/detail.
Start with a larger number for the target edge length and lower it until you’re happy with the results, I think I was using 0.1, but maybe start with 1.
I see. I’m getting closer results. I’m still having an issue where I can’t get the flat internal portion of the “horn holes” to render.
The model you worked is is almost perfect to print, but for sake of assembly and hiding seams, I was hoping to have it break out the way it was in the original model where the ridges of the horn holes hide the first seam on the horns.
I’m tempted to run yours as is and just dice it up in my 3dprinter’s hardware but wanted to float this by you once more and see if there was a simple solution. I tried splitdisjointmesh to break it up and I’m not having any luck getting at the individual meshes after I split it up.
Ah, makes sense. The horns look good to print, and are a separate mesh in your original file so splitdisjointmesh won’t do anything there. The shrinkwrapped mesh is continuous so that won’t split either. I’ve Shrinkwrapped the head section and used it to boolean the horns to fit, see;
Halloween_Small SW.3dm (12.9 MB)
For your shrinkwrap settings, I think you still need to patch the underside. If you’re getting no result with inflate unchecked then you essentially have a thin skin rather than an enclosed model. See below for the surface I quickly drew in. There’s gaps, but the shrinkwrap can span these.
