If I use the _Move command in Rhino 5 to move a mapping widget of a texture you have a real-time preview of the texture position, which is great to visually pinpoint a texture. In Rhino 7 though you need to finish the _Move command in order to see the texture position update.
I find this rather cumbersome and I wish we would get back the Rhino 5 behavior.
Hi Tobias - here it does indeed work on 7.5. I see a lot of non-standard plug-ins in your System Info that I do not have … I guess we should start eliminating those one or two at a time and see if we can point a finger at one of them.
Talking about plugins…I don’t really get why Bongo is listed twice with 2 different names. Seems messed up to me. But I’m reluctant to remove it cause there was trouble to get it activated when I installed it
OK, thanks. I was hoping I could find a flaw in your process. I don’t know why it is doing this for you and not here. Before I ask the bigger brains, can you send me the object, and texture, to try? Maybe my test is too simple.
I wonder if this has to do with Advanced Texture Preview maybe. In case you have fiddled with display mode settings it may be good to try restoriing them to their defaults and see if this improves.
Hi Nathan,
You were right that it had something to do with the rendered display mode settings. “Advanced Texture Preview” made no difference but I had “Use advanced GPU lighting” off. Turning that on fixes the issue.
Thanks for pointing me in the right direction!
Tobias
