I cannot change materials, add different ones, map them or customize. I can only load whatever is standard in the download. The render option panel pop up does not have any options to convert. Help. midterms
Assigned to Rhino category.
Hi @Jennifer_Stonerock , What version of Rhino are you using, Rhino 7 probably but I want to make sure. Can you tell me how you are accessing materials? Is it with the Materials panel and is Rhino Render set as the current Renderer? Screenshots would help too to understand what you’re doing and where.
Yes Rhino 7. I try accessing the materials 2 ways. Either through the layer or from the render tab, click the tube of paint. The problem is twofold.
When I access materials through the layer, the pop up material panel appears but without any options for modify the materials. If I click through the series of custom, I can get to the Rhino material folders and pick one of the provided materials, wood, metal, plastic, etc. I can place them as they are but no modifications, no custom materials, no bump, nothing.
When I click the render, tube- the pop up panel never shows up. The description says, yes for it to appear but nothing. (Yet the pop up appears for layer materials)
Are we able to set up a meeting? Can I zoom with you so I can share my screen? I am super frustrated because no one has a solution.
I’m available for a meeting, tomorrow from 10-1130a or sometime Friday.
Jennifer
@Jennifer_Stonerock Can you use the Materials command to open the Materials panel and edit materials via that? If not, myself or another tech can do a remote session with you. Email tech@McNeel.com to set that up or call our tech phone line at 206-545-6877. I’m on the email today and tomorrow and can send you the link to connect if needed.
@Japhy is out at a tradeshow so that may be why, I can help sort this out.
I’d like to schedule a meeting to resolve the material issues with Rhino. I have already uninstalled and reinstalled and still have issues.
The Materials command does not open material panel. The material panel in layers does not provide any customization, mapping etc. The material application in render does not work either.
I’m available Friday after 1130.
Jennifer
What is your current renderer set to?
I’m confused by your question. I do not know how to answer.
Jennifer
Andy means the Render drop down menu in Rhino > Current Renderer flyout. Is that set to Rhino Render? BTW, I emailed you back yesterday from our tech support address with instructions for if you wanted me to remote control your machine. Reply to that email please if you are ready. I won’t be on tomorrow but another tech will be able to remote in if that’s your only option time wise.
ok. I can work on it later today or tomorrow. I downloaded it before but the person never joined. Not sure if I was doing it correctly.
Okay, I don’t see a reply to the email I sent with the access number and time your machine will be on for us to remote in. Please reread the email and if it isn’t clear what you need to do, reply to that email not here and we can help more.
Can you help?
1 159 200 896
call us 206-545-6877 8-5 pst
