For some reason in the Rendered mode over here (either Default or with some customizations), the “locked wireframe” of the original that should show when transforming the object is not visible over here, unless both Sun and Skylight are ON:
All other display modes work OK.
Any idea what could be causing this? Here is the SysInfo file:
SysInfo.txt (3.2 KB)
thank you for any suggestions,
–jarek
