Ngons rhino wip
I am new to rhino wip rhino-common but I would really like to test new ngon functionality.
What I would like to do is to create simple mesh let say with 5 vertices and get information about adjacency of faces adjacent to edges.
Thank you.
Here is a mesh with ngons that you can try: Dodecahedron.3dm (34.2 KB)
This block of code should be able to make one:
/// <summary>
/// Creates a planar mesh from a closed, planar polyline curve
/// </summary>
public static Mesh MeshFromPolyline(PolylineCurve curve)
  Mesh mesh = null;
  if (null != curve &&
      curve.IsClosed &&
      curve.IsPlanar() &&
      curve.PointCount >= 4
    if (4 == curve.PointCount)
      mesh = new Mesh();
      var a = mesh.Vertices.Add(curve.Point(0));
      var b = mesh.Vertices.Add(curve.Point(1));
      var c = mesh.Vertices.Add(curve.Point(2));
      mesh.Faces.AddFace(a, b, c);
    else if (5 == curve.PointCount)
      mesh = new Mesh();
      var d = mesh.Vertices.Add(curve.Point(3));
      mesh.Faces.AddFace(a, b, c, d);
    else
      mesh = Mesh.CreateFromClosedPolyline(curve.ToPolyline());
      if (null != mesh)
        var vertices = new List<int>(mesh.Vertices.Count);
        for (var vi = 0; vi < mesh.Vertices.Count; vi++)
          vertices.Add(vi);
        var faces = new List<int>(mesh.Faces.Count);
        for (var fi = 0; fi < mesh.Faces.Count; fi++)
          faces.Add(fi);
        var ngon = MeshNgon.Create(vertices.ToArray(), faces.ToArray());
        if (null != ngon)
          mesh.Ngons.AddNgon(ngon);
    if (null != mesh)
      mesh.FaceNormals.ComputeFaceNormals();
      mesh.Normals.ComputeNormals();
      mesh.Compact();
      if (!mesh.IsValid)
        mesh = null;
  return mesh;
– Dale
Thank you for a reply.
Do N-Gons have any adjacency information to other ngons?
How should I find all ngons that are adjacent to one of the ngon?
Do ngons know about each other? I tried to look into mesh edges, vertices and faces, they do not have any property to get connected ngon or similar.
To specify my question about adjacency I was going through documentation and could not find this:
This is only face - face adjacency. Maybe @dale has a better advice on this, but this works too, I have not sorted out Mesh Edge - To Ngon and vertex To Ngon relation, and also do not know what happens when mesh face or ngon is deleted, but this works when ngons are just initialized:
Adjacency
Iterate over mesh faces in ngon and get connected faces
if that face does not belong to the same ngon add to adjacency list
        List<int>[] faceAdj = new List<int>[mymesh.Ngons.Count];
        for (int i = 0; i < mymesh.Ngons.Count; i++)
            List<int> faceAdjTemp = new List<int>();
            uint[] meshFaceIdInCurrentNGon = mymesh.Ngons[i].FaceIndexList();
            for (int j = 0; j < meshFaceIdInCurrentNGon.Length; j++)
             int[] id = mymesh.Faces.AdjacentFaces((int)meshFaceIdInCurrentNGon[j]);
              for (int k = 0; k < id.Length; k++)
                    int ngonID = mymesh.Ngons.NgonIndexFromFaceIndex(id[k]);
                    if (ngonID != i && !faceAdjTemp.Contains(ngonID))
                        faceAdjTemp.Add(ngonID);
            faceAdj[i] = faceAdjTemp;
But I agree it would be nice if ngons have some adjacency properties within each other
