New user, help to create points from a mesh of lines
Hello to the community.
I am a new user of grasshopper and I could use your help.
I was trying to make a structure with a cross mesh, unfortunately making the mesh entirely out of sheet from the beginning turns out to be cumbersome.
I’m trying to create a line mesh, in which I’ll remove a part of it with a solid. Then what I would like to do is to use the crossing of the remaining lines to create points and integrate my geometries.
However, I’m getting stuck and I need help to move forward.
I would like to use the crossing of the lines to create points and integrate my geometries.
Thank you
help beginner.gh (30.8 KB)
I’m not entirely clear about your objective. This looks a little different in some respects but it’s simple, well structured and easy to modify. For example, I used one ‘XYZ_space’ and ‘XYZ_count’ slider for all three dimensions but you can easily have separate sliders for X, Y and Z.
help beginner_2022Oct19a.gh (25.7 KB)
P.S. Same thing with separate sliders for X, Y and Z ‘space’ and ‘count’:
help beginner_2022Oct19b.gh (26.1 KB)
Thank you so much. It’s amazing what you have done. Thanks to you, the project is going to take another step forward.
I will keep you posted on the final result.
May I continue to ask you questions if necessary?
I am happy to answer questions about any code I have posted. More general forum questions depend on whether or not they are interesting to me.
