I am a beginner in the Grasshopper program and I would need help to make the following structure. Could someone tell me where to start or what path I should follow to be able to do this?
Thank you so much!
Guillem Torrentalle
Thank you so much!
Guillem Torrentalle
Hello
as points are shared on the lines, I scale the edges in order to not have points near the ends onf face edges.
Then Populate Geometry
There are some random number on each line, number could be limited to 1 to Max. A graph mapper is added in order to have more flexibility.
Each point is re affected to the face then in order to order point a delaunay component is used to generate a convex hull
Then using 3 points you can draw a curve, the middle point is on a line between center and border.
