Thank you! I knew I’d overcomplicated it using the hole tool. Redrafted in 2D only > Polar array of tiny holes - grouped - then linear array of that to make 6-up. Extruded the whole lot in one go and passed over to Keyshot…
This 3D CAD malarky is a bit tricky for an Adobe Illustrator boy…
Won’t be long until I’m stuck again…but getting further quicker with Rhino than anything I’ve dabbled in before!
Hey, it might also be worth checking out how the ‘history’ works. In this way you can still change parameters of your operations, even after all the duplications. What could be possible for example, is to change the hole size afterwards if you do it smart.
…one last thing - is it possible to actually define the size of an object accurately? Only seem to be able to scale via a scaling factor - so currently bringing in Known-size DXFs for the models I need to work on but thought I’d be able to amend sizing values directly?
Select point which will be set to desired distance from the base point as the first reference point.
4} For “second reference point” do not select a point. Instead enter the desired distance from the first reference point.
Single click after Scale and you can type the ‘factor’.
Double click, if you use Scale and make a first and second reference point, you can then enter the desired length for the distance between those points instead of entering the ‘factor’ as in the single click method.
And a smart remark, philw, you could’ve easily found out yourself. Just go to youtube and type in the search bar: rhino scale. It is maybe even less of an effort than asking it on the forums
[quote=“ohmarinus, post:9, topic:22269, full:true”]
Or shorter:
Double click, if you use Scale and make a first and second reference point, you can then enter the desired length for the distance between those points instead of entering the ‘factor’ as in the single click method.[/quote]Second method is the same as what I described in the post above.
[quote]And a smart remark, davidcockey, you could’ve easily found out yourself. Just go to youtube and type in the search bar: rhino scale. It is maybe even less of an effort than asking it on the forums
You get tons of videos explaining:
[/quote]??? I’m not going to take time looking for a video to post a link to when it is quicker for me to type my response to a question.
