New RUI issue
I was brave and dared to make a new ‘Toolbar group’ yesterday.
The goal is a RUI to distribute.
All was fine up to a certain point, then all was lost.
So today I tried again with a simplified data set.
TestSVG.zip (18.5 KB)
In the end, all was lost again.
Do I do something wrong, or is the system still not reliable?
SysInfo
Rhino 8 SR9 2024-6-11 (Rhino 8, 8.9.24163.15301, Git hash:master @ 17c7f1c7c05ff0e0b5b12288d13a911b1f0767b4)
License type: Commercial, build 2024-06-11
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.9.24163.15301
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.9.24163.15301
hi @Charles thanks for sending the files.
there is still some mix-up happing with rui and xml files, and so far I haven’t been able to pinpoint how it happens.
When you closed the toolbar, did you have any other instances of Rhino open?
When I open your toolbar, all seems fine:
OF COURSE not :laughing:
Is that on Apple?
In Windows I have this:
Also note the stacked button in Child1.
yes, but I get the same result in Windows.
For some reason Rhino doesn’t clean the xml files it generates.
I bet you get a good toolbar once you find the similarly named xml file in your Scheme_Default folder
(%appdata%/mcneel/rhinoceros/8.0/settings)
I didn’t expect that, but still needed to make sure :slight_smile:
Now I tried something, in
%AppData%\McNeel\Rhinoceros\8.0\settings\Scheme__Default
I deleted
Oh same idea…
Ok, after deleting that file (while the SINGLE instance of Rhino was closed), it works.
I’ve been hunting this problem for a while, but unfortunately cannot reproduce it on my end. Here the xml always gets erased correctly when I save the rui and close Rhino.
I see the same in here now…
I’d expect the xml is killed right after the rui is saved.
And not when Rhino shuts down.
If Rhino should crash or somehow forgets what to do, killing the xml wouldn’t happen.
Yep, that is my experience too. @stevebaer shut off the automatic saving of .rui files awhile back because there were too many bugs when that happened… A number if them have now been fixed. I don’t know when it should be turned back on…
Now that I understood what can happen, I was sure that creating a new toolbar with more than 3 sample buttons would work.
No, it doesn’t.
Every 2-3 buttons I explicitly saved the RUI.
The XML was killed on shutdown Rhino.
All should be good.
On next Rhino start: Toolbar destroyed.
I can’t provide steps to retrace the errors.
My ‘solution’ for now is
  • make 2 buttons
  • copy the RUI for backup
  • copy the XML for backup
  • save the RUI in Rhino
  • close Rhino
  • start Rhino
If I’m lucky, then I can continue making buttons.
If not, I have to fiddle with my backup copies.
Now I could express my mood, but that won’t help either.
Dunno, I recently made a toolbar with 18 buttons in one go, and it still works fine.
However, that being said, I no longer make new toolbar buttons in the classic way. I first make all the macros that will go in the LMB/RMB via the Macros dialog, including macro name, commands, tooltips image etc. Then I make all the buttons, choosing the macros from the library.
Good you found a reliable workflow.
I think I’ll copy your workflow when it comes to the next catastrophe.
For now I’ll continue, I’m half way through.
Puh, finally ready now.
Around 110 buttons in 4 toolbars.
Took me 1.5 days.
Time for creating the SVGs not included.
I had to use my intermediate backups quite often.
In fact I had to make ~500 buttons :sleepy:
Did I mention that the process is easier and much much faster in V7?
@charles, I tried following your process to recreate the toolbars the way you did in the video, and it just worked well for the most part. I agree that deleting the xml right on save should be better, but I’m afraid it is not going to work very well with multiple instances open. But @stevebaer will be able to judge this better.
I will ask what the current status is regarding the xml files for custom RUI files. As mentioned before, the ultimate goal is to get rid of them completely for custom RUI files.
Sounds good!
The multiple instances ‘problem’ is still the same.
Perhaps a warning like
'Multiple instances detected. The last closed Rhino will win writing the settings.'
could be helpful.
I think this is related:
Today I tried to make a new toolbar with 3 icons.
The goal is to distribute the toolbar.
Looks good.
My RUI is 1KB.
Nothing in it.
But an XML file with some content.
The XML doesn’t go away on save.
Rhino 8  Ursprüngliche Datei aktualisieren
Datei gespeichert in
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\BlaBla\1.0.0.0\BlaRhino8.rui
Aha, cool.
No, not cool, 1KB.
XML still exists and doesn’t go away.
I feel that “Datei gespeichert in” is a lie.
It would need admin rights for that folder.
I only want to make a toolbar with 3 buttons.
Nothing complicated.
I’m not a magician, and I DO NOT want to fiddle with XML files.
The “new” toolbar system is still more than frustrating.
I’m tired of reporting issues now.
My solution: I’ll never again try to create a toolbar.
