[New plugin] Terra - Terrain modelling made easy (with tutorial)!
Hi guys! Terrain modeling in Rhino has always been brutal. Tedious workflows, unpredictable results, endless manual adjustments.
I have been working on this plugin called Terra and this plugin transforms terrain modeling from a painful necessity into an intuitive, even enjoyable process. Real-time editing. Intelligent automation.
:sparkles: What Terra Does:
  • Create Landforms:
    Gif_LandformCreation2_3MB
    CreateLandforms
    Basic Interactive Terrain Modelling:
    TerraModelling
  • Path Creations
CreatePath
Sequence 01_1
  • Real-Time Feedback -
    ManipulateterrainEasily
  • Platform and Tunneling
  • No Grasshopper. No Scripting. No Headaches.
:construction: Currently in Beta Terra is being refined and tested. If you work with terrain regularly and want to start using and testing this tool, feel free to drop me a message! I will send you a copy of my plugin.
use the below link to download the plugin.
Hi all,
thank you for some of the interests I received.
The Terra Plugin is now available on the PackageManager on Rhino.
Simply Type PackageManager => search for Terra => Click Install.
Once installed type Terra to start the plugin
Press Alt to call the widget to toggle between different modes.
Just drop me a message if there’s any problem.
More than happy to support anytime.
It works!
Some update!
in this Youtube video, I created the Charles Jencks Landforms in less than 5 minutes.
If you need some landform modelling, Please try out Terra and let me know how you think!
Thanks for some of the feedbacks I received!
Apart from the various bugfixes, in the next few updates, I am planning to introduce more features:
  • Optimizes Surface Generation from Features
  • Cut and Fill Analysis
  • Wind and CFD Analysis
  • Better terrain display which incorprates roads and waterways
  • I am also exploring how to incorporate AI chatbot so to generate the diagrams more easily for architects. Things like, map out all the residential buildings around London, or map out all the parks in Berlin… and more!
Stay Tuned!
Hey guys.
I have updated Terra to produce Sunlight Analysis in less than 20 seconds.
Please update your Terra to the latest version!
Hey guys, In the latest version, the notorious layer panel crashing bug has been solved! thank you for your feedbacks!
Command: Terra_ImportSite
BBox: (44,490847,11,308807,44,492163,11,310170) Mode=Photorealistic3D
Site import failed: Google tiles JSON failed 404 Not Found: {
“error”: {
“code”: 404,
“message”: “Requested entity was not found.”,
“status”: “NOT_FOUND”
hi I’m no more able to import from google 3d, does some other has the same problem? tX!
Hi Francesco,
Thank you for reporting.
I found out there were 1,360,876 Map Tiles request last month and it totally busted my API quota.
I upgraded my API and now it should be working now.
