New feature in Rhino WIP 2017-Sep-19: Render view sources
We extended the rendering panel with a view section that allows to specify which view should be rendered. The options are current viewport, specific viewport, named view or snapshot. At the moment this feature is only supported by the Rhino Render.
RenderViewSource
What is a “specific viewport” and how does that button work?
Specific viewport means “Always use the viewport specified for rendering”.
This means you can set “Perspective” as the viewport, and it no longer matters what viewport you were working in last - when you press the render button, it’s always the perspective view that gets rendered.
I see. I presume that there is some mechanism (not evident in the screen shot) for the user to “specify” the desired viewport? Can it also be a named view or snapshot?
AIW
I would suggest you try it!
  • Andy
