New Behavior (?) RH-6 World/UCS AXES
I have some components that have the World/UCS Axes showing up other than in the default position and at the default size.
The normal AXIS management control commands don’t seem to help.
here’s a pic showing the problem:
This happens at every occurrence of this valve, throughout the installation.
ANY suggestions ?
Thanks !
C. Fee
Hi C -
There is nothing in native Rhino that looks like that.
Please run the Rhino SystemInfo command and copy-paste its output here.
Are you sure they aren’t part of the imported component? Can you select them and delete them?
Yes that was exactly the culprit !
The Nuts I imported from the manufacturer had them still turned on in the model. I just opened the offending nut in the native CAD program (AutoCAD), turned it off, re-saved, and replaced ONE nut on every valve ( ;=) ! ) and all returned to Rhino-Universe normal ! Whew !!
Thanks !
C .
