Hi everyone,
I need help with this model, the surface do not align with base curves that I use for Network Surface command
what I already did
- Increased the surface count in network srf command
- adjusted the units to 0.00001
NETWORK SRF.3dm (178.0 KB)
Hi everyone,
what I already did
Hi @Krishaangeli
Only a single of your open curves actually touch the closed top and bottom curves. When there’s a gap - in this case multiple fairly large and visible gaps - between the two curve sets in NetworkSrf the resulting surface will be an average between the two “input directions”. In other words, the resulting surface will follow neither of them. Make sure that your curves line up using osnaps like end, near etc.
fantastic thank you, it actually work! i was afraid to connect them because there is another surface that should be connect on it
