Hi Menno Deij - van Rijswijk
Thank you for taking a look at the file. I have now attached three .3dm files, as well as screenshots showing the relevant stages of my workflow.
- File 1 contains the curves immediately before creating the Network Surface.
- File 2 contains the resulting Network Surface.
- File 3 shows the later stage where I isolate a portion of the surface and encounter the problem when trying to lay it out with CreateUVCrv.
To make the input geometry easier to follow, I separated the three main curves by color:
- 1st curve – Green
- 2nd curve – Orange (inverted pear-shaped)
- 3rd curve – White
Here is my workflow up to Cut to Ring Rail.
- Creating the first curve – GREEN
I first created the ring rail at EU size 55.
In Front View, I created four reference lines from the quadrant points of the ring rail:
- 7 mm upward from the top quadrant
- 2 mm outward from the right quadrant
- 2 mm outward from the left quadrant
- 1.5 mm downward from the bottom quadrant
Still in Front View, I then created a circle.
The initial diameter of this circle was not important to my construction. I used the reference lines above to establish its final proportions.
I used Scale1D in the required directions until the curve reached the End points of these reference lines. The endpoints of the 7 mm, 2 mm, 2 mm and 1.5 mm reference lines therefore determined the main dimensions and proportions of the curve.
After establishing the basic proportions, I created a BoundingBox around the curve and used CageEdit with the rectangular bounding box as the control object.
I used a 4 × 4 cage and adjusted the cage points to further reshape the profile and obtain the required outer form.
After completing these adjustments, this became my 1st curve, shown in green.
- Creating the second curve – ORANGE
After completing the first green curve, I made a copy of it and rotated the copy by 90 degrees.
I then switched to Right View.
Before rebuilding the curve, I created a Line using F4 with the BothSides option enabled, so that the line passed completely through the middle of the curve.
I selected the curve and used Split, using this line as the cutting object.
After splitting the curve, I deleted the right-hand half and kept the left-hand half.
Only after this Split operation did I use Rebuild on the remaining half-curve with:
I turned on the control points with F10 and manually adjusted them to obtain the required half of the inverted pear-shaped profile.
Once I had the required shape, I mirrored this half to the opposite side and used Join to join the two halves together.
This produced the complete inverted pear-shaped profile and became my 2nd curve, shown in orange.
- Creating the third curve – WHITE
I then switched to Top View and created another circle. This became my 3rd curve, shown in white.
I used Scale1D to adjust its proportions until the white curve intersected both the 1st green curve and the 2nd orange inverted pear-shaped curve at the required locations.
At this stage, my three principal curves were:
1st curve – Green
2nd curve – Orange, inverted pear-shaped
3rd curve – White
- Preparing the curves for NetworkSrf
At this stage, I did not split or modify the first green curve. It remained a single closed curve.
I only worked with the 2nd orange curve and the 3rd white curve.
First, I used Split to split the orange inverted pear-shaped curve with the white curve at their intersections.
I then performed the reverse operation: I selected the white curve and used Split again, this time using the orange curve to split it.
So the orange and white curves were mutually split by each other at their intersections.
After these operations, the geometry I used for the Network Surface consisted of:
- 1 closed curve – the original green curve
- 4 open curves – resulting from mutually splitting the orange and white curves
So immediately before NetworkSrf, I had:
1 closed curve + 4 open curves
This exact geometry is included in File 1.
- Creating the Network Surface
I selected these 1 closed + 4 open curves and used:
Surface → Curve Network (NetworkSrf)
to create the surface.
The resulting Network Surface is included in File 2.
This is where the issue already appears.
Before using Cut to Ring Rail or doing any further surface operations, I can already see the edge running through the middle of the Network Surface when I use ShowEdges.
So this edge is already part of the result immediately after NetworkSrf.
I then used Cut to Ring Rail to cut the Network Surface according to the ring rail and create the ring form.
What happens later
After Cut to Ring Rail, I continued the model, but the later workflow is only relevant because it revealed why this existing edge is a problem.
In short, I duplicated the required edges of the surface and offset them on the surface to create a closed curve.
I then used this closed curve to Split the surface and isolated the area inside the curve.
When I try to lay this isolated surface out flat using CreateUVCrv, it is not treated as one continuous surface. Instead, it is divided into two parts along the same middle edge that was already visible with ShowEdges immediately after NetworkSrf.
I have included this stage in File 4, so you can inspect the actual surface that I am trying to lay out with CreateUVCrv.
Ideally, I would like to correct the cause at the NetworkSrf stage rather than moving or working around the edge afterward.
Thank you again for your help.
