I am trying to create a complex surface network and doesnt matter what it just doesnt create it.
All curves are closed but dont know if the problem is that they are so many or just cant get to solve it.
I have 4 days already trying and nothing works.
Here is the file in case you want to try it. ARM CHAIR.3dm (918.4 KB)
Hi Will,
If you’re trying to run the NetworkSrf command on that geometry, you will still need to divide the geometry into groups of lines that are organized in a way which the NetworkSrf command can handle,. See the help topic for the command.
Creates a surface from a network of crossing curves.
Note: All curves in one direction have to cross all curves in the other direction and cannot cross each other.
If you test selecting only a few curves and it works, then you can add more curves and find out where you broke the rules.
Hi Will - I’m afraid nothing good can come of trying to make this shape from a single network surface - have I understood correctly that that is what you’re shooting for? You might have a look at the section on surface topology in the level 2 training material - http://www.rhino3d.com/download/rhino/5.0/Rhino5Level2Training/
to get an idea of why this is not really a single-surface shape. NetworkSrf is a fine tool, but it is not a substitute for planning your surface patches and using the various surfacing tools that are available… if it could do this and get what you want, there would only be one item in the Surface menu!
