I am having trouble figuring out how to use the “C” option in the NetSurf component.
it seems referencing surface edges from rhino has no effect if tangency or curvature is set.
I am also not quite sure how one would actually feed a surface edge into the NetSurf component if the geometry was coming from grasshopper directly.
ok, thanks for the info! it seems as if there is “only” the edge(from surface) geometry type missing as entity, because i really wonder why the option 2&3 are in there. probably for later developments.
concerning the blend itself, G1&2 continuity are available in the blendCurve node, which i currently use to create the network curves, but it could save a lot of time to get the surface edge directly, if no additional controls are needed.
