Sweep2 rails: edge continuity and/ or Blendsrf component
I am looking for an option to create a 2 rail sweep in Grasshopper with an option to set curvature continuity to G2 for the rails. Is such a component available in a plugin or with custom code?
The same goes for a Blendsrf component with inputs for G!/G2 like you can find in Rhino, is that available somewhere too?
Thanks in advance!
G1 meaning tangency and G2 curvature?
There is an api method that can be called.
I’ve put it in this for you.blendsrf.gh (51.2 KB)
no idea about sweep2 tho
That’s great!
For the last 45 minutes I’ve been trying to rename the inputs, because I use full names and that makes it easier to remember if I save the component for reuse. I couldn’t get it to work with my names despite replacing them in the script itself… :confused: Would you be so kind as to rename the inputs like this:
blendsrf.gh (49.0 KB)
try this
Awsome, I am going to use this thing like crazy! :smile:
@Will_Wang if possible can you please have a look at this.
I try to use blendsrf on this example but with didnt work as expected :frowning:
Any ideas how that can be solved usingyour script?
Thanks in advance
blendsrf_gsy.gh (10.4 KB)
it seems to me that the RhinoCommon call can’t handle singularities at the two ends where the edges meet. Not sure who would know better. Maybe @dale
Hi @g.synetos,
If you bake your geometry to Rhino and then run the BlendSrf command, do you get the results you expect?
– Dale
@Dale yes it works as expected.
@Dale do you have any idea why that happens, and do you have any alternative solution how to achieve the desired result?
Hi @g.synetos,
I am able repeat the problem, and I’ve opened an issue.
https://mcneel.myjetbrains.com/youtrack/issue/RH-62323
The only alternative I can provide at this time is to use this version of Brep.CreateFromSweep. Include the points where the edge curves intersect. You’ll need to cook up at least one shape curve. You should be able to use Brep.CreateBlendShape to do this.
– Dale
Thanks @dale
Is there any example on how i can use these functions?
While i m fluent with python, i m not familiar at all with VB or C#.
I suppose it should be something straight forward to just call such a function but i m not familiar with the syntax :frowning:
Thanks!!!
Brep.CreateBlendSurface Method failed.gh (19.8 KB)
I am trying to blend two surfaces using @Will_Wang 's script today but still had an angled edge.
I am not sure if this is because the script hasn’t gotten an update or if the bug still remains.
The first picture below is a comparison between BlendSrf in Rhino and The script.
Hi @Quan_Li,
The Brep.CreateBlendSurface and the BlendSrf command are only similar in name only - the former does not use the same code as the latter, which is unfortunate. The goal is to have the two work the same. But this won’t happen until sometime during the Rhino 8 release.
https://mcneel.myjetbrains.com/youtrack/issue/RH-74177
– Dale
Got it, Thank you!
Hi there,
I just wanted to see if in 2025, any new solution or native components added to GH other then gh plugins exist?
I face the same type of issues as others with best option we have so far @will_wang C# component.
In Rhino I manage to make it work tho. using tangency option.
So it seems that its only a matter of adding these options to the GH component. Anyone good at coding did tackle this ?
blendsrf_2025-05_cc_v1.gh (36.3 KB)
Thnx !
blendsrf_2025-05_cc_v1 Edited v0.gh (70.4 KB)
Not perfect at all, but for this specific case this might be a solution.
@dale it is a significant waste of resources when you have already developed such a powerful function yet have not implemented it in Grasshopper. The same logic applies to MatchSrf and Subd Edge Crease.
@Quan_Li,
Issues you can follow:
https://mcneel.myjetbrains.com/youtrack/issue/RH-14867
https://mcneel.myjetbrains.com/youtrack/issue/RH-79547
– Dale
Hope to see further developpement soon on it. Thanks for the work in progress.
@Quan_Li, your solution for now is my best bet! Appreciated.
One question still, it appear that with “trimmed surface”, the definition you provide will miss an isocurve at the beginning and at the end. I don’t understand the behavior here…
CC_BlendSRF_v1.gh (191.6 KB)
CC
Maybe this can help.
