Let me first start by thanking you for creating this magnificently useful Plugin for Grasshopper!
I encountered a problem when trying to nest objects with a relatively high spacing between them (attaching files for reference):
- It seems to create spacing between the nested elements and the sheet curve itself, with the spacing increasing as I increase the spacing.
- It doesn’t seem to be efficient when the sheet curve is concave. As you can see in the example, it is easy to manually find out that the nesting was actually possible.
Thanks again for your help
Nesting_Distance_Example.gh (13.7 KB)
Nesting_Distance_Example - Copy.3dm (19.4 KB)
