Nested blocks change transformation when blocks edited
I am experiencing an issue whe editing blocks in rhino for mac.
I have a model with nested blocks, each time i edit the parent block, the nested blocks transform to a new location/orientation. My friends are also experiencing this issue. I have added a small test model:
Untitled.3dm (3.2 MB)
Hi Tim-
Thanks for reporting this an providing the sample file. I am able to reproduce the behavior you are describing. I’ve logged this bug (MR-2868) and we will look into it. Please take a look at the logged issue to make sure I’m describing the bug correctly.
I should also say: if you know of a way to reproduce this behavior in a new, fresh, 3dm file and can provide steps, that would also help us. If not, the file you provided is a great start.
Best,
-Dan
Hi Dan,
thanks you for logging the issue. I didn’t succeed reproducing the issue from scratch so far. I did update to version 5.2.2 recently, possibly the file was originally created with the previous release. Could this be of influence on the file itself?
best regards,
Tim
Telefoon +31 624957360 Website www.timcastelijn.nlhttp://www.timcastelijn.nl/ Adres Bavelselaan 268, 4834TH Breda
Van: Daniel Belcher mcneel@discoursemail.com
Verzonden: dinsdag 6 september 2016 23:08
Aan: t.castelijn@hotmail.com
Onderwerp: [McNeel Forum] [Rhino for Mac] Nested blocks change transformation when blocks edited
[https://sea3.discourse-cdn.com/mcneel/user_avatar/discourse.mcneel.com/dan/45/9535_1.png] danhttps://discourse.mcneel.com/users/dan McNeel
September 6
Hi Tim-
Thanks for reporting this an providing the sample file. I am able to reproduce the behavior you are describing. I’ve logged this bug (MR-2868http://mcneel.myjetbrains.com/youtrack/issue/MR-2868) and we will look into it. Please take a look at the logged issuehttp://mcneel.myjetbrains.com/youtrack/issue/MR-2868 to make sure I’m describing the bug correctly.
Best,
-Dan
Visit Topichttps://discourse.mcneel.com/t/nested-blocks-change-transformation-when-blocks-edited/36473/2 or reply to this email to respond.
To unsubscribe from these emails, click herehttps://discourse.mcneel.com/email/unsubscribe/6d9930c692f291d0ca1b620bd7bbe58d8e41ddabaf80d8e185a37f1edfa74766.
It certainly could, so thank you for providing it. We’ll look into it. I just thought I would ask if you could provide steps (often this is not easy to do).
Thanks again,
-Dan
I am experiencing the same problem with nested blocks as well. I tried different things to reproduce the problem but seemed kind of random when it happened. I think now I found when the problem happens.
If I have a block which I nest into another block everything is OK. However, when I rotate or mirror the blocks and place multiple of those in another block, the rotated/mirrored ones jump all over the place while the original one(s) (which was not rotated/mirrored) stays where it should be. This happens when editing the parent block as Tim described.
Can this help you?
.Jeroen
Hi @dan,
do you have any idea when the issue will be adressed?
best regards,
Hi Tim!
We would like to get this bug (MR-2868) addressed sometime during the 5.4 release cycle. Unfortunately, I cannot be more precise than that. @JohnM may have a better timeline as this item is on his list. The only thing I can say right now is that it’s in the “next up” pile, but - until we dig into it further - it’s not at all certain when it will be fixed.
Sorry for the delay,
-Dan
https://mcneel.myjetbrains.com/youtrack/issue/MR-2868 Has been fixed in 5.4.
This bug should be fixed in the latest RhinoWIP (5E63w). Please give it a try.
I’ve tested the latest WIP and blockedit works as expected now. Thank you!
